1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Industry: Construction Equipment
Role: Product Architect/Option Manager
Stakeholders: R&D , Production
2. What version of Windchill are you currently running?
11.2
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Wanted functionality:
Only The Global Option Managers should be allowed to create and edit O&C and Global Rules in the Global Library (VCE Common Option Pool).
The product containers will use a subset of the globally available O&C in their Local Option Set.
The Option Manager in the product container should have full rights to create Local rules in the Local Option Set without needing to have full manager access to the Option library
4. What is the use case for your organization?
Clear separation of responsibilities
5. What business value would your suggestion represent for your organization?
Medium
