View Creo drawings in PDF format within the Search window by clicking on a PDF icon
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Machine Tool Industry
Retrofit Design Team Leader
2. What version of Windchill are you currently running?
8.0.2.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Trying to view a Creo drawing quickly by reading it in PDF instead of having to fire up Creo View Express
4. What is the use case for your organization?
To save extensive time repeatedly opening drawings in Creo View Express
5. What business value would your suggestion represent for your organization?
Daily ability to view and cost parts for quotation purposes
5 Comments
JCDelord
2-Guest
Sorry, I accidentally put in Creo version 8.0.2.0. when I meant to put Windchill 12
BenLoosli
23-Emerald II
The files are already in PDF format, just stored in Windchill as a .pvz file, which is opened in Creo View.
You can set up a publishing job that will create the PDF and save them to disk when the Creo View file is created.
The purpose of utilizing the .pvz files in Windchill for the Creo View viewing is that there is 1 copy of the file and everyone sees the same information. By creating a PDF copy that can be opened in Adobe directly, who knows if someone has the latest information compared to the Creo part/assembly. There is also the issue of extra disk space being consummed by the PDFs, especially if people start to take copies of the file.
MikeLockwood
22-Sapphire I
Windchill Extensions has a free simple extension which adds a link to published PDF's in Search Results as a column.
From Search, one click brings up the PDF.
https://windchill-extensions.ptc.com/kb/articles/quick-access-user-documentation
olivierlp
Community Manager
Hi @JCDelord   Please let us know if the suggestions you received work for you.
olivierlp
Community Manager
Status changed to: Alternate Solution
Changing the status in light of the conversation.
