View and Control Agreement Association from the Authorized Object
The use of Agreements is made more difficult that it needs to be by only allwoing visibility and management of relationships between and Agreement and its Object from an Agreement. To truly understand the impact of the jurasdication an Authorized Object falls within it needs to be seen on the Object, take for the case creation of a derived work from potentially more than one source, a decision needs to be made what Authorization the derived work will require and also a concious choice to include or exclude portions to reduce unnecessary access limitations.
This would be best achieved by adding a capability to display the labels that are active (already possible in 10.2) but also a hyperlinked Object Reference to the Active Agreements that apply as well. Ideally being able to associate or deassociate an Object to an Agreement directly from the Object and removing the step of navigating to the Agreement should be provided as well.
3 Comments
Alexandrite
In 10.2 M030 PTC has added a Related Agreements report that can be added to a tab on an object's information page when security labels and agreements have been enabled.
Participant
That will be a very valuable addition to the existing capability!
The other half of the idea is that allow adding a relationship to an agreement from the new table, this would obviously only be available to users with the relevant permission but it would be a significant time saver in our case.
Community Manager
Status changed to: Archived
