Behavior in MAPSB
Multiselect Parts using Shift Key, all the selected parts are highlighted in Visualization
Behavior in Part Compare window
Multiselect using Shift Key highlights only the first selected part in Visualization
Suggested Behavior in Part Compare window
Multiselect using Shift Key should highlight all the selected parts in Visualization
