To suppport multiple cad document related to one Part you can use Image link as an association to a Part.
For example a sealing ring, you ca have one model that shows the sealing in a unmounted state. This model have a Owner Link to the Part.
Then you have one or more cad document that have the sealing ring modelled in a mounted state. (changed diameter).
These CAD document you associate with Image Link to the same Part.
Then you use the mounted models (with image loinks) in a Cad ssembly.
If go to the CAD structure tab an looka the visualization tab, this visualisation shows the correct cad representations.
But if you go the Part Structure tab this visulaization is incorrect.
Here you see the default representation of the Part, which is the represenation of cad model with owner link.
So, the enhancemnet that must be fixed, ic that it showed be posible to dynamically visulaise a part structure with parts that have image linked cad documents.
This visualization is vital in Manfuacturing Product Structure Browser (MPMLink)
