WC_Inspector file contents checking
0 Kudos
i would like to suggest an improvement to the WC_Inspector batch tool.
As of writing you are able to check registry settings, file existence, environmental variables. However, you cannot check the contents of any files, specifically of interest to my company is the wgmclient.ini found under C:\Program Files\PTC\WGM by default. We would like to make sure certain values like cache.size are set to the correct values using WC_Inspector as our analysis method.
Would this be something the PTC development team could add to a future version?
1 Comment
olivierlp
Community Manager
Status changed to: Archived
