WCC 10.1 Hide/Remove from the table selected objects
Hi
there is a great functionality to reduce the size of the table (folder, search results etc...) which allow only to display the selected objects. This is as good as it is possible to select all the wanted objects at once. An enhancement would be the possibility to hide/remove selected object from the table.
For instance. I have 200 objects. I want the table to only show the object of interest but I cannot select them all at once. so I proceed by elimination. If I had the possibility to remove the unwanted object from the table. I could select some unwanted click the bottom to remove them, continue to browse my results, remove a few more, etc...
In addition, the export to file should allow to only export objects visible in the table and not all. Otherwise I have to do that filtering again in excel,
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
