The Max To Retrieve field on some of the WPA search criteria screens needs to be configuable. The system has a value of 100, and we have configured the number of rows to display on the Search Results screen to be higher than that value. If the user does not notice the Max to Retrieve field setting, they may think that is all of the data that was available to display on Search Results, when in fact there is more data.
