The Reported date on the Supplier Info page on Material Compliance tab on Report History tab should be equal to the date in the EICC file (Completion Date or Effective Date depending on the EICC revision). It sometimes matches the file date and is sometimes off by one day.
When create a Supplier Request and set due date, the date displayed on Request tab is sometimes off by one day.
This may be true for Supplier Part Request. This was not tested.
This may be due to time zones. We tested this using testers in different time zones and had inconsistent results (some testers were off by one day, some had correct day).
All dates in WPA should display the correct date. This affects audits of the system and communication with suppliers on when data was sent or requested.
