The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
When upload an IPC that did not have the correct Company ID, the error stated that the Supplier Part did not exist. This is a misleading error message.
In this case, does the Company ID exist? Can you please provide an example?
added example
