The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
WPA need to be able to enter substances greater than 100%
Substance data is usually reported as a range of percentages.   Worst case for compliance may require assumption of maximum content of multiple constituents.  If the maximum values are chosen, the total will exceed 100%.  im constrains this sum to equal exactly 100%.   Recommend that this be changed to a minimum of 100%.   This will result in an overall mass of a part in WPA that could exceed its actual value.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
