Need the ability in WPA to define a workflow.
For ex., a person needs a verdict for a part. Supplier is created in WPA. Supplier part and company parts are created. Supplier and/or supplier part request is generated. File is received from the supplier. File is accepted. Original requestor is notified that the data is available.
