WPA - needs to provide the ability to save search criteria to be used later
WPA needs to be able to save Search criteria that was entered by the user.    They system should provide the ability for the user to name the saved search.   The saved searches should be displayed to the user.   The user should be able to select a saved search and re-run it or edit it and re-run it.
PDMLink provides this capability.    Similar capability should be available in WPA.
1 Comment
Regular Member
Also this options was implemented in InSight. And many clients queries for the same feature in WPA
