WPA needs to provide xls files to create the load file and instructions on how to convert the file to a txt file to be loaded. (users cannot do their editing in a .txt file). Better yet, allow all uploads to use xls format (some upload options do and some don't).
The Help is helpful in identifying what data goes in what field, but samples are needed to get the user started.
