In WQS 10.2, FMEA Generate LSAR feature, the mode number drop down doesn't contains the causes category.
If a user uses the system as is, not all FMECA causes will appear in the LSAR file since it only shows data 1 cause level.
USER must trick system by assigning mode and cause identifiers as unique per mode and cause in order for it to work.
Mode number, doesn't refer to FMEA failure modes only, Mode Number should be Failure Mode Identifier Number and should include selection of variables in cause category.
