If the user doesnt have access/permission to review a data field, it should not be searchable with the search engine. Neither should it be searchable within the table view or with an existing filter (that is set to filter a data field that is not included in the user groups predefined locked table format). A suggestion for improvement of the FRACAS module is to introduce a possibility to limit the data fields that a user has access to in the user groups table format file. So, when a user perform a Google Search in the WQS web interface, he should not receive any search hits for data fileds that is not present in his groups Table format file. Neither should it be possible for the user to create a filter, containing a data field that he doesnt have access to, according to his user groups table format file.
