WT Classification - add node document and/or node/attribute images
Within the WT 10.2 m030 classificaiton, we can add a node specific "Schematic" image.  While this is a good first step, we need to make it easier for users to classify parts by helping them to understand the specific node and attributes. To help them we need node specific documentation and images.
Please add enhancements for either or even both:
  1. Similar to schematic image, allow a node specific document.  The idea is that this document explains the part background and all attributes via text and images.
  2. Allow node and attribute specific images. For each classification node and attribute allow an image to be loaded, the icon should be on the same line as the attribute. The image would then be very specific for the part & attribute.
Both of the above enhancements should be available when creating/classifiying the part and when searching for parts. The icon to open the document/images should be "loud" and obvious so that it is not overlooked.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
