I have added 3 transfer gates to FTA diagram.
Please see the attached file.
The gate 5 is only one gate which are connected to 3 transfer gates (2,3,9).
I would like to see the all of gates by using the "Disable paging".
However, it shows attached error message.
Can you modify it so that I can use "Disable paging" when we use same transfer gates more than once ?
Thank you
