When checking in an AutoCAD Document into Windchill I would like to run some validation testing on CAD document. Like standard check in Creo.
When checking in an AutoCAD drawing I would like to run some standard checks on the drawing format which includes dimension, text, and table styles.   In addition a purge of unused objects would be extremely helpful.   Inside AutoCAD there is a Standard Check system that is run with a CHECKSTANDARDS standard file *.dws.    I have found aways to interrupt the WGM "ACADADATER_CHECKIN_CUSTOM" command by turning off and replacing it inside the WGM ribbon menu.   This is great as I can do the things I suggested above.    What I find is that our users can use all the other places to check in that do not allow these tests.   Can this feature be added with a preference so that it can be run when set.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
