When duplicating a WTPart, user should be able to select whether linked WTDocuments shall be linked to the new WTPart or not
Currently, it is possible to set the behaviour system-wide whether the copied WTParts should also have links to the previously linked WTDocuments or not.
This is currently possible to set for describing documents and reference documents separately.
It would be good if "copy with or without links to WTDocuments" could be set for each WTPart by the user individually in the "Save As" dialog list.
5 Comments
JeffZemsky
rweber
6-Contributor
Hi Jeff,
thanks for pointing to the existing (bigger) topic/ idea.
Please ensure that "Copy of WTPart with cutting the Link to the WTDocs individually" is considered there also - I am to completely sure whether this is already covered by the descriptions I found there.
Regards, Rainer
saw
11-Garnet
11-Garnet
https://community.ptc.com/t5/Windchill-Ideas/Copy-wt-Part-without-copying-Described-By-document/idi-p/467922 = duplicate.
To expound on your idea, each type, Described By and Reference, should have an option to copy the link or not.
HelesicPetr
"Copy of WTPart with cutting the Link to the WTDocs individually" has not been implemented.
So the idea covers that needs.
Vote for it.
olivierlp
Community Manager
Status changed to: Archived
