When validating usage link attributes isQtyUnitAttributeChanged() method retuns incorrect result.
0 Kudos
While validating usage link attributes SavePartUsesSubCommandDelegate.validateUsageLink(TypeInstance var1), isQtyUnitAttributeChanged(AttributeContainer var0, AssociationIdentifier var1) method should return the comparison result based on previous value and current value.
Hence getting Exception "Occurrences exist that must be removed before the unit can be changed" while updating usage link attributes programatically.
FileName: \com\ptc\core\foundation\occurrence\server\impl\SavePartUsesSubCommandDelegate.java
          \com\ptc\core\foundation\occurrence\common\OccurrenceHelper.class
i.e.
Previous QtyUnit = 'EACH' Current QtyUnit = 'EACH'
if previousQtyUnit.equals(currentQtyUnit) then
     return 'FALSE'
Else
    return 'TRUE'
As per current implementation method returns TRUE even if no QtyUnit is updated.
if currentQtyUnit != null then
     return  'TRUE'
3 Comments
vyewale
hello, Is there any updates on this?
vyewale
Hi Team,
Any updates on above idea? Are you planning to take it ahead or needs more details on this?
olivierlp
Community Manager
Status changed to: Archived
