Where used for choices should answer with rules
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What version of Windchill are you currently running?
11.2 and 12
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
We need to trace choices to rules in the option set. (it works correct in the Option pool but not in the option set)
4. What is the use case for your organization?
Sales configurator needs to read the rules defined by R&D
5. What business value would your suggestion represent for your organization?
Traceability increases efficiency
3 Comments
olivierlp
Community Manager
Hello @JE_8968323.  Thank you for your idea.
JE_8968323
9-Granite
Clarifying the idea with 2 more screenshots.
My need: find the rules where choice 1046 is used. Include rule 442 should be found where used choice 1046.PNGInclude rule 442.PNG
olivierlp
Community Manager
Thank you for the additional information: more is generally better for product ideas.
