WindChill Copy/Paste Folder Structure within a Product
Our company currently uses one product in Windchill and all of our engineering work orders go into subfolders of this product. Each work order has a specific folder structure. We have been told by PTC that there is no functionality for a simple copy/paste within a given product. There are articles from cases in the PTC support help on this, which suggests people want it. There is a huge need for this functionality. Links:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS44995
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS21305
3 Comments
LawrenceS
18-Opal
This method of exporting appears not to work for WC12 as the export template is blank.
TomU
@LawrenceS,
This export is working fine on Windchill 12.0.
The referenced file should be inside the CONTENTS folder in the exported zip file:
Did you make sure to select folder structure?
olivierlp
Community Manager
Status changed to: Archived
