Currently, when using the WindChill Visualization pane within the structure tab of a WTPart, the method to use the measure tool is very different from Creo. You need to select one entity and then SPACE and then the second entity. It would be great if there was an option to use the Creo method, where you select the CTRL button instead of the space bar.
