Windchill 10.2 OOTB Business Rule framework does not support to adding a new rule to an existed rule set by using loadfromfile command.
If you want to load a new rule, either we have to load a new rule set or delete existed one and reload it again with the new entry, which both are not a feasible options.
So may be in future releases PTC can improve on BusinessRule framework by adding loadFromFile as an option to add a new business rule to existing Business rule set.
