An alternative method is to create all the documents via ZIP using the standard browser interface. It will create all the folders along with the documents (excluding empty folders at this time), with the only caveat being all the documents will be assigned the same document type.
This is a good suggestion and the possibility intiating a ZIP Import from a drag-n-drop action is a great suggestion.
