Windchill Quality Solutions: Default Font Definition Report Designer
It would be nice to have the functionality to define a default font for new fields in the report designer.
At present every data field/text field and so on you insert in a new report design would be of font Tahoma, 10pt.
I request the functionality to set another default font, because otherwise you will have to change each and every text field you insert in your report design manually, if you do not want to use Tahoma.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
