We would like to be able to open other files other than what the WGM is specifically for from the workspace. For example, when assembling a file (Creo) in Inventor it will only allow you to see Inventor files in the workspace. Once you are out of the Workspace it will allow you to see them. All these files exist in Windchill so they will added to the Workspace and not retrieved from the hard drive.
