Windchill alias attributes should be able to map with CREO parameters without any customization.
0 Kudos
we are using Windchill PDMLink with Creo Parametric and Creo Elements Direct Drafting.
by now we are still on Windchill 11.0 M030 but an updateproject is running to 12.0.2.x
in our case we are not able to get additional information from a user into creo that are already made in the LDAP.
We would like to use alias attributes in Creo so we could handle some additional information f.e. from userprofile to show in frames of drawings. This could be like last name or additionalname or location just ootb.  in other words, we would like to make the userprofile more useful
2 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @MichaelHacker for publishing your idea. However, you provided the bare minimum for your idea. We need more information as specified in the form you saw in the submission process. You may simply add a comment to your idea. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
Here are a few examples of well documented ideas:
start Save As from Replace - PTC Community
Enable object update for multiple workspaces - PTC Community
Merge occurrences in Compare to Part Structure too... - PTC Community
Subcontract enhancement - Ability to define contex... - PTC Community
Windchill preference values on user & container le... - PTC Community
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
