OOTB Windchill gives a warning ONLY while expanding the structure if circular references exists.
This is not sufficient since this can cause several issues in WT and downstream systems.
Therefore it should be prevented at all cost like on the CAD side.
Desired would be to prevent this on insert or checkin of a BOM.
If this is not possible with reasonable performance this should be checked during release by a business rule.
