Windchill to provide OOTB preference to set the Lock Option to Yes while creating a new Baseline
0 Kudos
This functionality is validated till Windchill 12.1 M010 and there is no OOTB option available to set the Lock Option to Yes while creating a new Baseline
The Lock option prevents unauthorized changes to the baseline. Once locked, the baseline becomes read-only. Only the user who locked the baseline can unlock it or make changes.
But user has to edit the Baseline to lock it if it missed to specify while creating the Baseline.
With a preference, a lot of user effort can be saved.
2 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @Jahagirdar for publishing your idea. However, we need more information. You may simply add a comment to your idea. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
Enable object update for multiple workspaces - PTC Community
Merge occurrences in Compare to Part Structure too... - PTC Community
Subcontract enhancement - Ability to define contex... - PTC Community
Windchill preference values on user & container le... - PTC Community
Windchill alias attributes should be able to map w... - PTC Community
Here are a few examples of well documented ideas:
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
