The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Window minimize and maximize option
0 Kudos
Kindly provide minimize and maximize option for all windows.
If there are lots of results populated in a window, we need to manually adjust the window size every time.
If minimize and maximize option is available, it will be easy to visualize the populated results.
4 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @Sathish_Rosario for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
For example, here is a recent well documented Windchill idea: start Save As from Replace - PTC Community
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
Sathish_Rosario
11-Garnet
Industrial automation product manufacturing.
Windchill 12.0.2.0
Results windows are smaller. We are not able to utilize the entire screen to view out interested objects.
This comment area also smaller (approx: 50% of screen area)
There are many sub windows inside a main window. When I scroll sub window, main window also moving.
Hence We need to stretch the sub window often.
If we refresh the page / re-login , then the sub window is reset to original size.
It needs to scroll up and down many times and eyes are irritating.
olivierlp
Community Manager
Thank you @ for the additional information. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
olivierlp
Community Manager
Status changed to: Archived
