Workflow Resource Pool - Setup Participants to use specific Context Role
0 Kudos
This update is a long time coming.  We really need the flexibility to make a Context Role (a role on the Product>Team) a resource pool for a "Select Participants" activity type in the workflow.  The Context team is FAR to broad and using a group doesn't work as it is not product/library specific.
Use Case: A Change Request workflow has a requirement where the person (CA1) who is completing the "Analyze Change Request" task need to select a specific participant who will then get the "Create ECN" task downstream.  Each Product has 3-4 people in a role called "ECN Creators".  These people are unique for each product.  When the CA1 does the "Select Participants" portion of the "Analyze Change Request" task, he/she needs to be able to simply hit search and see these 3-4 users as available for selection.  Currently this isn't possible, though its an INCREDIBLY common request.  As of now, I have to use the Context team; however this is usually 100 users +- and is unacceptable by the users.  Yes a group would work but its unacceptable as well as it is not unique per product (there are many products).
5 Comments
JeffZemsky
GregoryPERASSO
Hello Jeffrey,
I have done several conf call with Debbie Schneider about this topic and my above idea.
Any new input about that ? is it planned in the 10.2 Mxx ?
We really need this functionnality, with exactly the same scenario as Stephen.
thanks
Gregory
Prabhash
Hello Folks,
I was just wondring, why can't you create a Team, add the "ECN Creators" role in this team.
Modify the workflow Activity node to include this newly created Role in to Resource Pool.
Prabhash
PTCModerator
Emeritus
Status changed to: Archived
PTCModerator
Emeritus
