Not only Part, CAD is the same.It is not make sense that Objects do not checkin to Context( still in draft stage) , workflow process had already been invoked . and execute business process logic
In this case the system does not know the workflow should not start.
What I would recommend is to put a sync robot in the workflow to not proceed until the Checkin action is complete.
