We have migrated our workflows from 9.1 to 11.0. When there is a workflow task that goes to multiple users (all users required to complete) at the same time and there is a routing choice of radio buttons, the task displays with nothing preselected, which is how it should. So a user makes a selection and completes the task. But when the next user looks at the task, the routing radio button is preselected with the previous users selection. I would expect each user to view the task and the routing options as not selected. This worked this way in 9.1, with the blank radio buttons for each user. I would expect 11.0 to still do this. So submitting for an improvement. The routing options should stay unselected for all users regardless if another user made a selection and completed the task.
