The Creo Elements/Direct Modeling Workgroup Manager for Windchill could use an "Update Titleblock" command for Annotation drawings.
This functionality is available in Model Manager integration with Modeling, and is useful.
Sometimes part/article information is put on the titleblock and when changed, the only workaround is to delete/load the drawing to have the titleblock updated.
Or when a new frame is put on the drawing, or ...
