CATIA service pack and hotfix version check between CATIA and Workgroup Manager is added at Windchill 11.0.
But our customer install CATIA hotfixes into all CATIA clients without notice so many WGM users will see the warning message about hotfix incompatibility after installation of the CATIA hotfixes.
Of course service pack version should be checked but we need capability that doesn't display the warning message if only hotfix versions are not same.
Also please refer attached material.
