Hello.
Is it planned to fully support the workgroup manager execution on windows server ? It seems to be partially supporter as it works (withs Solidworks in our case), but it can't regulate the allocated memory, and takes more and more memory until the server crashes (15Go used only by uwgm_client.exe).
We don't have this problem on CAD workstations, but we have to use the worker on our server wich runs on windows server 2016. Support can't help with this problem, the only solution is to kill the process with helper script.
Thanks.
