Whatever is reported in the information/detail page should be able to be shown in a column in the Event Manager main view. It doesn't have to be pretty, it just needs to be there so we can search by it and actually find the frame we need!
Event manager main view:
Information/Detail Page:
This is where you would see the .prt, .asm, and .drw CAD names that are affected by the event (no event is shown in the above screenshot)
More details if want:
WS Frames are nice when you need them and you happen to know the exact date and time of the object that you need to restore. However, if you don't know this it is painful and arduous to find the right object because there is currently no way to search.
Example:
Say I have a part with the file name or number "NUT". but there are many other objects that I have been working with in that WS. How do I find that object? You can search the table but sadly you cannot display a column for the file names that are affected in the frame. This makes it very hard to find the frame that you need. If you could search the table by P/N "NUT" it would be a lot faster and WS frames would be a lot more useful!
PS. The way Labels are done on this website are useless. I have no idea what this should be. Creo Integration is not available.
PPS It is lousee that i cannot copy and paste an image in this message because it tells me that I cannot exceed 20,000 characters!
