allow ALIAS attribute to show attribute value from latest iteration of part and documents
The current behavior when we have an ALIAS attribute point to a part/document IBA attribute, it would show multiple values from all the iterations of the object.
It would be beneficial to have syntax to show the value from the latest iteration.
1 Comment
Patrick2
In general it should be possible to restrict alias navigation by constants / literals. Notation for conditions could e.g. be in square brackets (similar to XPath).
Examples for proposed solution:
  • Navigate only to WTParts where latestIteration=1
    describedBy@wt.part.WTPartDescribeLink~describes^wt.part.WTPart[latestIteration='1']~name
  • Navigate only to WTParts where lifeCycleState=INWORK
    describedBy@wt.part.WTPartDescribeLink~describes^wt.part.WTPart[lifeCycleState='INWORK']~name
  • Navigate only to WTParts where latestIteration=1 AND lifeCycleState=INWORK
    describedBy@wt.part.WTPartDescribeLink~describes^wt.part.WTPart[latestIteration='1' and lifeCycleState='INWORK']~name
