The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
allow to set different Change Object Templates located on ORG level as default in different contexts
It should be allowed to set different Change Object Templates located on ORG level as default in different contexts.
As is:
If a Change Object Template is created, it is stored on ORG level.
Only one Change Object Template for a specific Change Object Type can be set to "Default" for all contexts in this ORG.
To be:
In the different contexts it should be allowed to set other Change Object Templates as default, independent from the ORG default.
