custom parameter should always be able to activate/deactivate
under some circumstance defined parameter are not switchable from visiblity to non-visibility especialy, if the parameter requires user input!
There are numbers of example that custom parameter can switch on and off based on needs.
If there are predefined ore reserved parameter names, which are checked against the custom defined parameter names, there should be an hint for how to use and define the parameter to accept it. (PDMLink 9.1 M050 and may be later)
2 Comments
JørnAHansen
2-Guest
If I understand your requirement the right way I think this is possible in Windchill 10 in the Type and Attribute Manager. you can define different visibility based on if it's the create, view or update display. I think also by role and there are ways to group attributes in collapsible groups.
PTCModerator
Emeritus
Status changed to: Archived
