When you save new models to Windchill using CEDM, there are 2 primary files stored: the content file and a lightweigt rerepesentation. If you are not using lightweight functionality, you are filling up your database with things you don't need. Creating the lightweight takes some time, which slows down the system.
Then is you load an assembly or add it to the workspace, content and lightweigt files are always downloaded upfront, eventhough you don't use them.
so if you have 20000 unique elements, your workspace will contain 40000 files! This doubles the download time of your entire assembly, while you did not ask for it.
we need 2 things:
PTC has here the opportunity to double the load performance of an assembly with CEDM, by just preventing a file type from being loaded. grab this opportunity with both hands, and make hundreds of happy customers.
