When you duplicate a part structure with or without CAD it it not possible to add additional attribute in the save as dialog for editing.
Only number, filename, name and location are available.
It would be nice if IBAs or MBAs can be added and changed by the user.
This prevents that the first iteration has invalid attribute values
and enables the effective use of object initialization rules for naming and numbering as well.
