-Ability to dynamically load Attributes or Informations from Windchill as CreoView parameters when opening a representation from a WTpart or any Viewable.
for example, WTPart attributes on a "content" linked CAD Drawing , or adding related Change Request information ....
Provide an API to be able to customize and add logic to retrieve and add significant parameter in creo View
-when partcentric, when open Creo View from a WTpart page, load in the same creo view session all the related Doc or CADdoc (ie not only the 3Dmodel but also linked CAD drawings, WTdocs ...)
-Being able to design watermarks specifically for 3D or 2D formats (for several paging format, A3, A4 , landscape, etc ....)
-Being able to choose , notably for 2D formats, if the watermark have to respect the zooming ratio.(and not stay with a fix size when zooming in a drawing)
The need is in a "pure Part centric" approach, being able to Vizualize, Stamp and/or print drawings (or other documents) with WTPart informations. Even if it is a "generic" multi part drawing. Or being able to have CAD drawings without any typical part information (BOM and part numbers, line numbers for drawing baloons, version, lifecycle state, title block, validators , etc ...) and only display/stamp them "on the fly" when print or viz
