Even the PTC Support gave me wrong information how to set the Maximum Filesize of the RollingFile appender for the MethodServer logs
the current setting should be written into the log4jMethodServer.properties file so that one can easily modify the Value
log4j.appender.methodServerLogFile.MaximumFileSizeInBytes=157286400
( the is also a setting MaximumFileSizeInMB -- but somehow this didn't work at all )
-- same is for ServerManager Logfile
