only the creator and the administrators should be able to see a newly created project
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Support responsible in defence industry
2. What version of Windchill are you currently running?
Windchill risk and reliability 11.1 CPS09
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Currently, everybody can see newly created projects. The creators usually don't change the rights associated to their projects. The improvement should be that  only the creator and the administrators should be able to access a newly created project.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
2 Comments
olivierlp
Community Manager
Hello @AP_9881109,
Thank you for your idea and the information provided. Similar comment here to your other idea Project navigator: Possibility to group projects b... - PTC Community.  You give the bare minimum of information...
olivierlp
Community Manager
Status changed to: Archived
