open the information page in New Tab
Click on “view information” button, and open the information page in New Tab or New Window of the browser. Users will benefit a lot from the function.
希望Windchill 10 能够实现每次点击“查看信息”按钮都能够启动一个新的浏览器页面和浏览器选项卡,这样能大大改善用户的操作体验。
6 Comments
dhermosillo
Don't forget to vote up your own idea.
STEVEG
This is already possible.  Hold down the Ctrl key then right-click on the link/view information button.
JeffZemsky
Stephen's comment is correct - this is available today using CTRL-right click.  Note that in PSB you need to add the column to use this.
MorganBelais
Jeff,
Web Standard to open in a new tab is the middle click.
Having to use both Keyboard + mouse is not really good for productivity.
No plan to improve ?
STEVEG
If you compare opening a new tab in 9.1 vs. 10.x it's actually less clicks in 10.x.  1 click for middle mouse button in 10.x vs. right-click then select Open in new tab (2 clicks) in 9.x.
If you are talking about opening a new page then it seems about the same to me.  Many people use the keyboard to work.  One of my co-workers tries to use the keyboard for many shortcuts.  Both in Pro/E and outside of it.
I like PTC adding commands to the right-click.  However, it's not consistent at all in what commands are in the right-click menu in the different areas of PDMLink.  As a perfect example...when browsing to a folder you can right-click on a FILE to select Delete.  But the Delete is NOT in the right-click for FOLDER.  You have to check the box of the folder, select the Actions pull-down menu THEN select Delete.  THAT is one area they really need to improve.  We are on 10.0 so I don't know if it's the same in 10.1.
There are many other similar situations.
PTCModerator
Emeritus
Status changed to: Archived
