Add a loadrule which loads a complete structure with the uwgm for creo elements direct modeling, and loads small parts partial. this allows you to load a very big structure, without all the details (nuts, bolts, ...) The size (surrounding volume) of the models that should be loaded partial, must be a user setting, and should be changeable upon load in you workspace. This will provide a way of more quickly loading huge structures. In addition, you should be able to add your own loadrules like you can in Creo Elements Direct Model Manager
