Is it possible to configure the rules and or the publisher and or Arbortext to generate multiple Published Content documents from a single Arbortext publication.
Create multiple pdf files and Published Content linked documents from the same Arbortext object.
The goal for publishing multiple PDF files as published content documents is to generate a separate document for each language in the publication source. (We define these items with profiles in Arbortext, the publisher recognizes these separate profiles using rules, however we need to understand the method to produce multiple, separate published content items.)
